Unigine SuperPosition Benchmark (UI BUG) help!!!
so many using it with win-10 there should be no issue ?? just make sure your win-10 if fully up to date that seems to be a big deal with stuff working under it correctly and try a new fresh download of it
matter of fact the heaven download I got from Unigine one time was balked . went to techpowerup and got it from them and it was good to go
try a new download of it ??? like if you got it from Unigine may try the download for like techpowerup ??
https://www.techpowerup.com/download/unigine-superposition/
I don't use the service called windows 10 / malware but works well under a OS like windows 7
maybe you got a bad download or its corrupted in some way ?
i havent updated my windows yet since there is no activator as far as i know for this version and i dont want the windows activation logo on bottom right of screen while playing games :/
