Several points to be made here.
1. The recharge time is wholly dependent on both capacity, and the run-time on battery during a power outtage. The longer you're running off the battery, the longer it will take to charge back up.
2. Age is also a factor all else being equal. The older the battery, the longer it takes to charge. In my experience, a UPS battery lasts on average 5 years. Though they should be replaced pro-actively every 3 years to ensure high availability when needed. It really depends on your wattage draw and how critical the need is for you. For the one at home, I only replace the battery when it's actually failed. YMMV
3. Some UPS units have to be re-calibrated (learning cycle) after replacing the battery. Essentially, you drain the battery until the UPS shuts off. It will then re-calibrate with a new baseline of 0 and charge up to 100%. This ensure estimated run-time at current load is properly being calculated.
