Hey everyone!
Next month I will be building my first Gaming/Home Entertainment PC. I have chosen to go with the Corsair 250D as it will fit my entertainment center, and would be a great centerpiece for my living room.
Here is my build list:
http://pcpartpicker.com/user/r.denluck90/saved/yGCZxr
I plan on having red LEDs to give it a cool glow out of the front and top window of the case. My problem is that I want to be able to control the LEDs brightness and would like to use the NZXT easy LED kit (http://www.nzxt.com/product/detail/101-sleeved-led-kit-case-accessory) since it would be so much easier to install and control.
The 250D only has two PCI slots on the back, and I will be running a dual slot GPU. How would you go about mounting the controller? My only idea is to have a friend who is a machinist cut a hole into the hard drive cage mesh cover plate that is pictured at the bottom left of this picture:
http://www.legitreviews.com/wp-content/uploads/2014/01/corsair-obsidian-250-exterior-3-645x661.jpg
From there I could either use double sided 3M tape or have my friend drill tiny screw mounts onto the grill. Any better ideas? I'm new to this. . .
