I Infantry01 Prominent Mar 10, 2017 1 0 510 Mar 10, 2017 #1 Hi guys i have a phillips cl034 universal remote and i cant get it to work with xbox360 it worked before batts died now i cant figure it out HELLLPPPP
Solution Ralston18 Mar 10, 2017 Trust that you replaced the batteries in the remote. And tried multiple known working batteries. (Not being facetious but I have recently encountered two situations where replacement batteries were bad.....) The next step is to verify that you correctly reprogrammed the remote for the xbox360. Usually some common identifying code is needed. Example reference: http://www.p4c.philips.com/cgi-bin/dcbint/urccf.pl?slg=EN&scy=US
Ralston18 Titan Moderator Oct 11, 2014 34,881 3,323 146,290 Mar 10, 2017 Solution #2 Trust that you replaced the batteries in the remote. And tried multiple known working batteries. (Not being facetious but I have recently encountered two situations where replacement batteries were bad.....) The next step is to verify that you correctly reprogrammed the remote for the xbox360. Usually some common identifying code is needed. Example reference: http://www.p4c.philips.com/cgi-bin/dcbint/urccf.pl?slg=EN&scy=US Upvote 0 Downvote Solution
