Question Universal replacement detachable mic for headset ?
ANXsucks
119
I'm using a JBL quantum 100 headset and the detachable mic is loose. Are there universal detachable mics on the market? Can I use replacement mics from other headset brands?
hang-the-9
It's loose meaning it works but wobbles? Just stick some putty or hotgun glue on it to hold it in place. I doubt any "generic" mic will have any better fit than one designed for the model. It also looks like a pretty cheap headset, if it's out of warranty and you like it, just get a new one.
