Universal Serial Bus (USB) Controller, and ACPI Unknow Device: Driver Problems
System Specs:
CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz, 4001 Mhz, 4 Core(s), 8 Logical Processor(s)
Motherboard: Asrock Fatal1ty B150 Gaming K4
Ram: Corsair Vengeance LPX 2400MHz 16gb 2x8gb
PSU: Corsair CX750M v2.3 New 4th Gen
HDD: Seagate Barracuda ST1000DM003
OS: Windows 7 Ultimate x64
two Drivers are having problems installing and i get the same errors for both, Ive installed windows 13 times with no luck as well as installing all the drivers from the webpage for my motherboard. Ive searched online and gone through hundreds of forums and solutions with no luck. This has been going on for the past 2 weeks now and I havnt been able to find any solution that works. Basically USB 2.0 doesnt work in windows and if i try to install USB 3.0 driver from the motherboard website it shuts off all the USB ports and disables PS/2 sim in windows and i then have to reinstall windows to get keyboard and mouse working on PS/2 sim again.
I get error code 28, Install Error E0000203 "There is no driver selected for the device information set or element", and problem code 0000001C for both.
Any help would be appreciated, Thanks in advanced
System Specs:
