Hello,
I am a university student and at my halls of residence each room has a wired internet port by the desk. This can be very annoying if you want to either connect your laptop elsewhere in the room or if you want to connect a mobile device for example.
To overcome this I purchased a Sapido RB-1602 pocket 3-in-1 Router, Access point and Wireless Bridge. However when I connect it to the ethernet port in my room my laptop has no trouble connecting but the university network requires you to go through a registration IP check and security check. This happens but then a pop up appears saying that 'the host is already registered'.
I contacted my IT support service and they said 'It's not possible to connect routers to the student network. Your laptop has a live IP address, but the wireless router will be blocked by Campus Manager.' I don't really understand this as it goes a bit over my technical ability but does anyone know if there is any way to work around this because it would really help if I could get this thing working.
Thanks, Rory
Thanks, Rory
