R Rigger2024 Reputable Feb 19, 2015 29 0 4,530 Mar 3, 2015 #1 I have a wire coming from my case with all the rest of my front panel wires and is says on it SD/MMS ? I don't no what it is and there no mention of it in the manual I got with the case
Solution giantbucket Mar 3, 2015 that's most likely a built-in card reader, SD (card) and MMS (card). most likely it connects to a USB header on the motherboard.
laviniuc Judicious Nov 29, 2013 5,504 18 32,415 Mar 3, 2015 #2 do you have card reader on the front of the case? what does the internal connector look like? Upvote 0 Downvote
giantbucket Dignified BANNED Nov 17, 2013 3,876 1 15,960 Mar 3, 2015 Solution #3 that's most likely a built-in card reader, SD (card) and MMS (card). most likely it connects to a USB header on the motherboard. Upvote 0 Downvote Solution
Mr5oh Splendid Jul 28, 2004 2,982 27 21,940 Mar 3, 2015 #4 This is usually for a card reader. Typically this was be plugged into a USB header on the motherboard. Upvote 0 Downvote
R Rigger2024 Reputable Feb 19, 2015 29 0 4,530 Mar 3, 2015 #5 giantbucket : that's most likely a built-in card reader, SD (card) and MMS (card). most likely it connects to a USB header on the motherboard. Thank you Upvote 0 Downvote
