• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Question Unknown cause of low frames
Jul 2, 2020
Hi... I have a desktop pc have the following specifications
Cpu: i7 2600 non k
Gpu: 5700 xt
H61 s2b motherboard
16g ram 1333 mhz limited by the cpu
Corsair 1000w power supply
Antec 902 case
I'm facing a problem of low frames that would be lower than the cpu and gpu potentials
The frames is low as 30fps -50fps or lower
I have searched on youtube if any one have the same components but i have found nothing exactly the same however i have found the same cpu with a gtx 1070 and the frames reaches 80fps that means the cpu is not the cause of the very low frames i know it will bottleneck the gpu but not to that extent
I hope i find the solution
The game i have tested is metro exodus.. but the issue takes place with most of the recent games except control
Jul 2, 2020
1080p, metro exodus, 50% each fluctuating up and down
Temp of cpu never exceed 65 degree
Temp of gpu never exceed 75 degree
Thanks for your reply
Jul 2, 2020
