Alright so i've had this computer for awhile. With the current setup I have, I have had no issues so far with, until recently.
I've never posted on tom's hardware so I had no idea where to put this post. If it is in the wrong place, I apologize.
My PC Has been having issues of randomly turning off. What's odd is that all temperatures seem fine. My GPU never exceeds 30-45C, and my CPU is stable around 67-80F.
(Yes. I used Celsius for my GPU and Fahrenheit for my CPU)
Never had an issue like this, please help if you can.
SPECS:
GPU - ASUS GeForce GTX 970
CPU - AMD FX-4300 Quad-Core (Vishera)
Power supply - 600w
RAM - 12.0 GB
System type - 64-bit
OS - Windows 10
Hard Drive - 2TB
If any of my specs are missing, I'm sure they will be listed here:
https://s31.postimg.org/7by71diq3/Capture.png
Thank you for anyone that has looked over and considered helping.
UPDATE:
It shut off again just now, and when I pressed the power button I heard me pc start up for like 2 seconds then shut off again.
SPECS:
Power supply - 600w
RAM - 12.0 GB
OS - Windows 10
Hard Drive - 2TB
UPDATE:
