First, I would like to apologize, I'm very green when it comes to computers and very recently this year, I had built a custom computer with my friend. I understand the very basics but I'll do my best to explain.
So my build, I currently have an i5 8600k intel core processor, a NVIDIA Geforce GTX 1060, and a 52x kraken liquid cooler. After assembling the whole thing together, I was able to run everything smoothly and the whole thing seems to be fine with one exception: the CPU temperature tended to be really high. When gaming, for example, Overwatch, my CPU would go up to 80-90 degrees C and sometimes up to 95 but it caps off at that point. After a while, I started to worry about the long term damage this was doing to my CPU so I figured there must have been a problem when we first installed the heatsink. So, I took off the case and reseated the heatsink, applying a new coat of thermal pasting and booted up my systems again. Now, it got worst. My temperature when gaming now goes up to 88-95 and I quickly close out the game as to not damage my CPU any further. My frame rates have dropped drastically, with it once being able to go at 60 FPS on ultra graphics, now limps at a solid 2 FPS and the graphics looks incredibly blurry. I checked my graphics card and it was a solid 37 degrees C so no problem there. So there is something wrong with the CPU and heatsink, at least that's what I assume. So what do you think? Does this high temperature cause my games to drop my FPS into the single digit? Is my heatsink broken and needs replacing? (It would be weird since I've just bought the thing this summer) Please, any help or advice would be appreciated.
Edit: Thank you for the answers given so far, I'll try to check and see if the fan isn't being connected properly. If it still fails, then I'll go replace it and see if that works.
