Unlock InsydeH20 Advanced Settings
Nov 2, 2018
Hello. I've been trying to switch between my dedicated and integrated GPUs with no luck. Then I found out that my BIOS might be limited to simple configurations. I need help to unlock my BIOS.
Inspiron 7520
Dell Inc. A11, 20/2/14
SMBIOS 2.7
Controller 1.01
What I tried:
- Fn + Tab / F10 + A when inside BIOS but those didn't work or maybe I did them in a wrong way.
Note: my dedicated GPU is a AMD Radeon 7700 and it's pretty much dead, that's why I'm trying to force my laptop to use my Intel HD Graphics 4000, but it only uses the MS Basic Display Adapter (I uninstalled the AMD driver) which is supposed to be the dedicated GPU. It's ignoring my integrated GPU.
Thanks in advance!
There is no "advanced settings" for an InsydeH20 BIOS, generally speaking.
The implementation by a vendor can vary, and there was, at one point ONE version of InsydeH20 that has an "advanced" feature - it's not commonplace.
F10+A would be how you'd access it, if it existed on your specific BIOS version. If that does not work, it does not exist.
