im not sure.but maybe hirens has solutions under HDD.using this to revive my hardisk back years: http://www.ultimatebootcd.com/.
i got lucky,try everything under HDD (i remembered was a chinese name who made it).your hardisk is corrupted.if found successful.install that OS again.if installed.u can create a recovery read below.
To install the Recovery Console, perform the following steps:
Insert the Windows XP CD into the CD-ROM drive.
Click Start, and then click Run.
In the Open box, type
d:'i386'winnt32.exe /cmdcons
where d is the drive letter for the CD-ROM drive.
A Windows Setup Dialog Box appears, which describes the Recovery Console option.
The system prompts you to confirm installation. Click Yes to start the installation procedure.
Restart the computer. The next time you start your computer, you will see a "Microsoft Windows Recovery Console" entry on the boot menu.
