Question Unreal Engine Games Crashes
Aug 26, 2022
4
i had alot of crashes lately most of them is from unreal engine and i tried all the software solution (fully format pc, uninstall new drivers , GPU clean install from ddu app in safe mode )
and i thinked maybe its hardware problem
so i tried to stress test my pc
tried cinebench for 10 min no crashes
tried haven benchmark for 30 min no crashes
tried prime95 and no crashes and before i tried memtest64 to check for ram problem and still no problem
no problem with hhd and my new ssd
and no problem with temperature
so maybe its not a hardware problem?
and nether a software probelm ?!
games had been crashing
apex legends ,fortnite, rumble versus ,the cycle frontier, hunt showdawn, raft.
and conqueror's blade
my pc spec:
i5 7500
gtx 1060 3gb
16gb ram 2400 hertz
evga 500B
motherbaord : msi b250 pro-vd
ssd: kingston A400 250 gb sata port
hdd:1tb from WD
latest windows update
latest gpu driver
if you want any more info please tell me. thanks
my pc spec:
i5 7500
gtx 1060 3gb
16gb ram 2400 hertz
evga 500B
hdd:1tb from WD
latest gpu driver
Oh yeah, those pesky UE crashes...
I've been playing a game called Remnant from the ashes for some time,
and i constantly experienced those crashes. Bluescreens,too...
Went through the same stress tests/benchmarks as you,
and none of them found any hardware issues.
Even memtest didn't report any issues.
But then i decided to just buy new ram sticks (had viper steel edition 3200's first,
then upgraded to corsair vengeance rgb pro 3200, mainly because i wanted more rgb anyway,lol),
and voila, never experienced a UE crash again. Sometimes all the tests bring no results,
but there's still an (undetected) faulty component. Hard to say what it is in your case, however...
Computers,huh?^^
sadly i wont buy rams to check if its gone work lol
my rams Corsair Vengeance 8gb two sticks ddr4 2400mhz
and yes i played Remnant from the ashes i remeber it crashed
"squad game "too
"squad game "too
I hear you there. Just figured i'll reply to this thread, as i was experiencing the same issue.
Do you by chance have other components (like the ram sticks, obviously) you can change
out just to see if the issue would still persist? Numbers wouldn't even matter,
as long as they're compatible with your system, and as long as you're sure they're in 100% working condition.
That would help you rule out a component already.
Good luck figuring out the issue, and hopefully someone else more versed than me can help ;-)
Computers,huh?^^
how much did you have and how much after buying new ram?
