[SOLVED] Unsure if HDD might have a problem
windenaifer
4
Hello, recently my computer is showing some weird behavior towards windows and its files corruption. This is the third time i had to format my computer due to windows simply going into blue screen when i try to start it. For instance, second time was on win 10 and third on win 11. I suspect its my HDD who is malfunctioning but i cant tell for sure. Crystaldisk shows it as a blue good and i dont understand the parameters that is shown enough to tell if there is a problem, so i`d like to request if anyone is able to figure out and if there is something wrong from this crystaldisk image: https://photos.app.goo.gl/YR6GqB8XXyhH2WKk6
SMART stats look fine, nothing jumping out to say I'm broken. I've had stability issues...
SMART stats look fine, nothing jumping out to say I'm broken. I've had stability issues with faulty SATA ports and SATA cables before. I would try a different cable first of all and then try a different port if no success.
I see, i had some bad sectors before but they seem to have fixed on their own back in Win10 yet it really is showing that there is no issues rn. Ill try to use some different cables to see if the problem persists
