http://www.tomshardware.com/answers/id-3586987/asap-grey-screen.html#20461417
I made that thread cause of GPU issues.. or so it seemed.
I'll try to make this short.
My PSU fan was making a lot of noise a few weeks back so I replaced the whole PSU. Shortly after doing that just days later, while gaming I got a big grey screen all across my monitor, I tried rebooting and playing some more then it led to blue screens and more grey screens and sometimes not even being able to boot up cause the GPU would get so hot. Which made me think that it would of been the GPU as I seen 1 other discussion over google on some website having the same issue with my GPU which made me 100% think it was a defective card only after a years use. So I replaced that just a few days ago. Right now I have the EVGA 600 B1 and GTX 1060.. Just yesterday almost the same issues arised. While gaming It would freeze completely, no grey screen but i did get a blue screen occasionally.. the same ones I had when I had my EVGA 600 B1 and the AMD Sapphire R9 270..
The following is what I read on the blue screen.
A clock interrupt was not received on a secondary processor.
When I check event viewer it says this:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly. Kernel-Power
And yes I did try and use the old PSU with nothing being wrong with it except a noisy fan to use my AMD R9 270 while I had it and still got the same issue hence why I thought it was a GPU issue instead of a PSU issue cause it happened on both the new one and OLD one.
I even went ahead and did a full clean install of windows 7..still happened while playing GTA V a few minutes ago.
Could this all be because of a Motherboard issue or maybe I was possibly sent a defective PSU or GPU? I'm at a lost for words and I don't know what to do.
