Question Upcoming mATX build, thoughts on case?
wolter.jeremy
22
So I'll be building around the 7800x3d and will post my tentative parts list below, I'll end up getting whatever is the best deal at the time. Mostly want input or options for my case as recommendations for mATX seem to be all over the place. Right now I've landed on the FD Pop mini.
Wants:
Top mount 240 rad support
As compact as possible so likely optimize airflow(i.e. mesh panels) but if its compact and performs well then that works
Good quality but I don't need to be spending ridiculous amounts on it, probably $150 at most.
Other parts
Mobo: whatever b650 with wifi is cheapest
RAM: seems like 6400 is the best bang for the buck, 6600 gets spendy quick. Not sure if CAS affects performance much on Ryzen
Gpu: TBD likely 7900xtx
Storage: m.2 2TB, whatever is a good deal
PSU: whatever reputable 650+W 80+ golf or better modular is on sale.
Cooler: totally up in the air, just threw the Nzxt in there
https://pcpartpicker.com/list/BKKVVw
Reactions: Why_Me
I would do it like this. Ryzen CPUs cannot often go above 6000mghz on the RAM so 6k with cl30 is typically the best you can do for RAM. An extra 5 dollars gets you a much better SSD. You want an 850w PSU for this system. I know its an ITX case and motherboard but it is on the larger and more compatible size for the standard.
PCPartPicker Part List
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler ($40.90 @ Amazon)
Motherboard: MSI MPG B650I EDGE WIFI Mini ITX AM5 Motherboard ($239.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($129.99 @ Newegg)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($122.99 @ B&H)
Video Card: Sapphire PULSE Radeon RX 7900 XTX 24 GB Video Card ($1029.99 @ Newegg)
Case: Fractal Design Torrent Nano Mini ITX Tower Case ($96.98 @ Newegg)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($149.99 @ Best Buy)
Custom: 7800X3D ($449.99)
Total: $2260.82
Generated by PCPartPicker 2023-03-21 15:06 EDT-0400
I really like the lay out of that Asus case with vertical airflow and front PSU. I know there's a Chinese branded one like something D31, any other designs you know of like that?
Reactions: helper800
