Updated Drivers, Audio is Quiet
FrostyClive
32
Specs:
i5 6600
msi h170a pro gaming
msi gtx 970 4gb
8gb ram Gskill Ripjaws V
Seagate Barracuda 1TB
Silicon Power 128GB SSD
About a week ago I updated my drivers via SlimDrivers, and my audio is very quiet. At 100/100, it is not very loud at all. Before I updated the drivers I had the volume at 50/100 and it was WAY louder.
http://download.msi.com/dvr_exe/realtek_hd_audio.zip
when the installer runs click on remove old install and reboot.
after it installs if the sound not there. go into windows sound device make sure realtech speakers are the default output. not nvidia hd or ati hd if your using headphones or speakers. leave that setting if your using monitor speakers.
if there still no sound look under windows sound that output not mutted. if it not the rear port try speaker in each prts starting wiht the green one. front headphone port and rear ports will only be two ports and not one unless in the realtech driver control pannel you take the check box off to makle front and rear audio two outputs.
