Hey guys,
I have been researching and browsing this forum pretty much every day for the past month or so and have hopefully come to a conclusion on what I want to build. Your advice has been incredibly helpful up to this point.
I have decided to go i7 after a long debate between it and the duo. While it's going to cost me an extra $600 or so, I think it will be worth it. I will probably not build until March, but I hope to keep these components the same, and hopefully the prices will have come down a bit by the time I get around to the build. I'm hoping to spend about $1500, not including the monitor which I might ask for for my upcoming birfday. This is what I've come up with.
CASE:
Coolermaster RC-690 - $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
POWER SUPPLY:
Corsair 750TX - $119.99 (w/o $20 MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
MOTHERBOARD:
ASUS P6T - $249.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
CPU:
Intel Core i7 920 - $294.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
CPU COOLER:
Coolermaster V8 - $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
GPU:
EVGA GTX 295 - $504.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130449
MEMORY:
OCZ Platinum 6gb - $169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381
HDD:
WD Caviar Black 640gb - $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
MONITOR:
Samsung 2433BW 24" LCD - $289.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001309
OPTICAL DRIVE:
LG 22x DVD burner - $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
THERMAL PASTE:
Arctic Cooling MX-2 - $6.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020
OS:
Windows Vista Home Premium 64-bit - $99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
In total it comes to a little over $2,000 after shipping and rebates
EDIT - Lucky change in plans and I will be order within the next couple of weeks. I made some changes, and am going to go w/ the 295 and P6t non-deluxe. The prices on some of my components are currently up on newegg but hopefully will come down again by the time I order. Also, I just realized there is a microcenter by my house (not college apartment) in VA so hopefully I can snag a 920 during their insane sale. ($230).
One concern I had was that I saw someone post problems w/ the corsair 750 and the gtx295. I believe that there are enough power connectors to handle it (I saw on a picture of the 750w that there were multiple 'PCIe' connectors which looked like 6 pin w/ a separate little 2 pin which I assume could be combined for an 8-pin. The 295 requires one 8 and one 6, so do you think this will be a problem.
Anything else you guys can see? Thanks as always!
CASE:
POWER SUPPLY:
MOTHERBOARD:
ASUS P6T - $249.99
CPU:
CPU COOLER:
GPU:
MEMORY:
HDD:
MONITOR:
OPTICAL DRIVE:
THERMAL PASTE:
OS:
