Updated Realtek HD Audio Drivers and lost all sound
KadiraDakar
Just installed Gamebooster and on its recommendation updated my Realtek Audio drivers. Sound was fine before I did so and now I have no sound at all. Registers speakers hooked up but Test results in no sound. Even tried my USB headset and also registers fine but no sound. Any advice is appreciated because right now I feel like putting my fist through the screen while chanting death to every company remotely related to computer hardware.
Never download "free" stuff that claims it will "boost" your computer.
Delete "gamebooster" and all other "free" programs first.
Turn off the antivirus and firewall, then load the update again.
Double click the speaker icon in the lower right hand of the desktop, this will bring up the mixer, or single click to bring up the volume control. Laptops: see below, third paragraph.
Check the setting of the mixer or volume control.
But in case the volume is missing, corrupted, or the audio is otherwise non-functional:
you check whichever audio was installed:
click start, click control panel, click add remove programs, look at the list...
which audio software is shown on the list? delete it, restart the computer.
now visit the motherboard manufacturer or computer manufacturer's website
look up your computer drivers by model number
download the latest audio drivers, save on the desktop...
turn the antivirus off,
if you have multiple security programs installed, turn them all off
(your driver may not install if security systems are turned on)
now load your new audio driver, restart, turn the antivirus back on.
Laptops: Your volume controls may be built into the keyboard. (varies according to make and model number)
OR: your volume control may be a knob, located near the headphone jack.
Download the entire manual for your computer model from the manufacturer's website.
The manual will show you where all the keyboard audio or wireless ethernet controls are located.
But besides the manufacturer keyboard controls, you will still have software controls, as above. (first paragraph)
So if "either one of these volume controls is turned to "zero" you will have no sound. If the Mixer is turned to zero, or muted, you will have no sound.
Hmmm, better check that.
