Question Updating graphics card problem.
kris05
Commendable
Jun 26, 2017
5
I have a pretty dated laptop still using a GT 720M 2GB version. Anyway, GeForce Experience is not detecting any updates for some reason so I went onto the side and looked manually. I'm about like 90 versions behind (latest is 471, and I'm on 390-ish). I downloaded the standard version and it said it's not compatible, even if I'm correctly running Windows 10 64-bit. Then when shifting the choices to DCH, there's none found. What gives?
Thanks.
kaehligj
335
23
695
4
You should never believe that different versions are the same.
Your try clearly proves it.
The available updates does not apply to the version you have, sadly it ends there.
kris05
Commendable
Jun 26, 2017
5
The weird thing is that GeForce Experience is also telling me I'm missing an update while telling me there's no new updates, so I was confused and though that the app was just malfunctioning and not able to download.
kaehligj
335
23
695
4
I understand your frustration.
I would be exactly as frustrated experiencing this myself.
I have been in electronics for more than 50yrs now (since age 16) and nothing can be taken for granted.
You have to be very stringent on specifications and differences herein.
