G
Guest
Guest
Thank you to all those who help!
I am updating my Asus Gene VI motherboard, on Asus' website. Since I just built my first PC ever, and have never manually updated a motherboard on a manufacturer's website, I am very confused. I see the different options, such as: BIOS, SATA, Audio, Chipset, Hotfix etc., but I have no idea what to download. Maybe only BIOS? Or maybe BIOS and Chipset? Or maybe every category listed? There are many others, such as Utilities, BIOS-Utilities, and the list goes on...
Also, on top of that, each category, such as "BIOS" for example, lists out even more options. I can't tell if each download is completely separate from the other, or if just one listing is "newer" than the other? In short, under BIOS, there are two options - are they different, or do I just figure out which update is the newest and download that one? I can't even tell which one is newest, if that is the case, which is why I am so baffled.
Here's an example:
BIOS (2) - See how it lists TWO different options?
Download Option 1:
Version 0615
Description MAXIMUS VI GENE BIOS 0615
1.Improve system compatibility
2.Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
File Size
5,2 (MBytes) 2013.07.02 update
Download from
Global (DLM) Global P2P
Download Option 2:
Version 0606
Description MAXIMUS VI GENE BIOS 0606
First release Bios
File Size
5,19 (MBytes) 2013.06.03 update
Download from
* Here's the the page I see on their website, for my motherboard:http://support.asus.com/download.aspx?SLanguage=en&m=MAXIMUS%20VI%20GENE&p=1&s=45&os=36&hashedid=rppozhc3zpbQrHmi
** If it helps, I am using this PC for Multi-Media, Gaming, and basic PC functions, such as Internet and eMail.
I am running Windows OS 8.
Here's an example:
Download Option 1:
Version 0615
File Size
Download from
Download Option 2:
Version 0606
First release Bios
File Size
Download from
