yes the motherboard is fine with that GPU, however the PSU needs a 8-pin (6+2 pin) power connector for the GPU.
nvidia calls for a 450W unit. if your PSU is not 450W or does not have the proper power connector then you cannot use that GPU.
you will need EITHER an 8-pin
or a 6+2pin to use that card
