ketav
i am just going to upgrade my cpu.i have thought of gettin e6420 core 2 duo
but i am confused about the chipset that i should install
.either intel 945g cost me 2400 rs
or d965wh cost around 7000rs
what i think is that the latter one is costly because its better on board graphics card.
But i also want to get a gpu
so isnt it better to use 945g and a gpu rather than buying 965wh and a gpu.
And ill b really thankful to you if you choose a gpu below 7000 for me from this page
http://tadkalive.indiagames.com/lofiversion/index.php?t5363.html
lfranklin
39
Yes the 965wh has better on board graphics than the 945g does, it might have better onboard sound, is newer, and probably will overclock better.
For the GPU, I would recommend either the Sapphire x1650 pro (right at 7000). But any ATI x1300 pro or Nvidia 7300 gt would probably do the job for you.
g-paw
Splendid
Jan 31, 2006
4,479
Suggest you google "reivews of Intel 965 motherboards" and you should find some articles that will tell you all the differences between the 945 and 965. Best way to confirm if a 965 is better, i.e., worth the extra money, for your needs. Don't remember what he differences were but I know every time a new chipset comes out there are articles regarding how they differ from the current generation
