Upgrade advice for PC build
scottishbullet
6
Hi. Last December (2012) I built a system on a budget with the goal of upgrading this year. I was (and still am) a novice when it comes to hardware but I did some research last year and got some help from a local computer store. I use my PC for video editing with Premiere and After Effects so that's my main focus to make faster editing and render times. Here are my specs.
CPU: Intel Core i7-3770 @ 3.4GHz
Motherboard: Gigabyte Z77-D3H LGA1155
RAM: Patriot Viper 3 16GB (4 x 4GB) DDR3-1600 Memory
Hard drive: 120GB 2.5" Solid State Disk (OS and Premiere and AE)
Hard drive: WD Green 1TB (Programs, Current Data)
Hard drive: Raid 1, 1TB backup for storing unused files (Will upgrade to 2 or 3 TB)
GPU: MSI Radeon 7770 1GB GDDR 5 Video Card
Casing: Antec 300 TWO ATX Case
PSU: Antec 620W 80+ Gold Certified Fully-Modular Power Supply
O/S: Microsoft Windows 8.1 Pro (64 bit)
So what would be suggestions on improving the hardware to get better rendering results?
H4X3R
Hey there :)
There is mainly just 1 improvement, the graphics card. I highly recommend that you buy an nVidia card so that you can use the CUDA technology to accelerate the video editing process. A good one would be the gtx 760, but it all depends on your price range. Please specify that.
scottishbullet
6
Thanks for the advice. I was able to pick up a GTX 760 and I can already see the difference. Can I get some input on the drive config? I've read so many opinions about this and there doesn't seem to be a good answer. Here is what I was thinking of doing...
1: 240 SSD - OS and APPS
2: 128 SSD - Media Cache (Scratch?)
3: 4TB HDD - Project Files
4: 1TB HDD - Renders (Previews)
Is there a better way to configure this? Sorry I'm such a newbie on this stuff.
