Question Upgrade CPU heatsinks when going from 80W to 135W dual Xeons?
iangreenhalgh
35
Hi folks
I'm about to upgrade the lowly E5-2609 Xeons in my Lenovo Thinkstation D30. These have a TDP of 80W each.
The E5-2667s I'm going to replace them with have a much higher TDP of 130W each.
What I'm wondering is if the stock heatsinks Lenovo supplied will handle the hotter chips?
I have searched and can't find any pictures showing any alternative coolers fitted to a D30 other than upgrades done by users so it seems that Lenovo supplied the same quite weedy looking dual heatpipe coolers with all D30s regardless of the CPUs fitted.
Stock coolers:
iangreenhalgh
35
Of course, that's why I ran the benchmark - to place a high load on the CPU to see how high it pushed the temp. I think 77C is within the safe limit.
Maybe I need to do a more thorough test where the CPU is under high load for a longer period.
iangreenhalgh
35
Those are exactly the same coolers as I have fitted. Only difference is that I don't have the momory coolers.
So if they will keep 2690s cool, they will be fine for my 2667s.
I'm considering buying some memory coolers, they are 20ukp a pair, as I have all 16 slots populated (16x8Gb=128Gb)
