Upgrade from core 2 quad 8300 to Ivy bridge or Haswell? Help
For your configuration the z87 board doesn't really offer much extra aside from 4th gen support. It has more SATA III ports, and that is about it.
Since you aren't overclocking you should go with the faster chip, which is the i5-4570 and H87 board.
Unless you plan on adding ram later, you should buy a ram kit with two sticks to enable dual channel memory. 2x2GB as an example.
Difference between single channel and dual channel, in terms of performance, is between 10-20%.
I suggest you don't bother getting a CPU upgrade.
You'll see a much bigger gain by upgrading your GPU.
What? Do not go to haswell. If you do, you will have a serious blow to your budget. Stick to sandy bridge or best case a 3220 or AMD A10 5400k(I recommend this) and get a gpu and crossfire it and have an awesome build. Don't make the mistake that I made.
Actually, he has a 550ti.
You're right about getting sandybridge. 'Tis a few quid cheaper, but Sandybridge, Ivybridge and Haswell perform the same; when overclocked, their thermal limits cause the equivalent chips to reach the same performance level.
I suggest he doesn't upgrade. If he really wants to, I advocate the AM3+ route with an 8320. Only upgrade that MIGHT allow a noticeable increase.
Just cut the crap and go with an older but higher clocking Sandy Bridge or go with lga 2011 as Ivy Bridge and Haswell have poor thermals that make then difficult to hit good clocks. If you do go with the newer models you will have to mod them by pulling the ihs and replacing the crappy thermal compound used with a liquid metal alloy based compound. As for everything else just listen to what people here are trying to tell you. No matter what dual channel is required for a balanced build.
Precisely .
In short @chapapa07 - Get a Sandy bridge(even ivy bridge if you can)
But If I were you, I would wait another 20 days and get the steam roller AMD CPU(s) coming out. They are going to be awesome for like a 120 bucks.
I would say if you are buying a 3350 better buy the haswell, coz atleast you would get a decent increase in computing if not the graphics(Which you are compromising). Try to get the best of atleast one of them.
Latest posts
