Question Upgrade from i54460 to i74790k make sense on current system?
Jun 20, 2019
Hello,
I just upgraded my Graphic card and Im thinking about upgrading my CPU.
Current system is:
Intel i54460
Gigaybte H97-D3H
16GB RAM
radeon rx570
500GB SSD
550W NT
There is not much room to upgrading from what I see outside of the CPU going to a i74790k. I dont want to buy a new system but I also dont want to spend money to get maybe 5FPS more. Would it make sense to upgrade?
Thanks a lot!
hftvhftv
Herald
May 26, 2014
642
66
11,090
22
Yes either a i7 4770 or a 4790 would be a good upgrade, but like you say you'll probably only get 5FPS more in some games, but when multi tasking the i7 would pose a significant advantage. If you just use it for games I wouldn't upgrade unless you can get an i7 for very cheap.
Jun 20, 2019
Thanks a lot guys. Yes its expensive to find. I found some stuff used on ebay and such sites. Will try to get a cheap one there.
Another different question would be, could I overclock my current CPU? Maybe buy a good CPU cooler and OC a bit? Or this CPU I have isnt OC ready? I have some experience 10 years go Overclocking but Im not at the current hardware knowledge to know if its possible now.
