Upgrade Hard drive or Case
June17th
88
I'm looking to make an upgrade on my computer. Currently not sure which upgrade to put money into. Debating on getting a 1TB internal hard drive, I currently have 250gb ssd, 250gb internal another 500gb internal installed. I figure it would make more sense to have the data on the 250gb and 500gb on one hard drive.
or a case.
I own a Cooler Master K280. Should I keep the case or invest in something else. Looking for a case up to 150$ Canadian. Which would be a better upgrade? Thanks
EDIT:
If it's possible to have a smaller case that can fit a GTX 970.
I get good airflow with it. Parts don't overheat. I should have added in the possibility of a smaller case with good cable management.
Than get a HDD if that's what you want : )
Western Digital is what I recommend they are the best quality ones, check prices, because 2 TB ones are not that more expensive.
