Upgrade help GPU
CharlesLewisM
41
Hey guys!
Need some advice on upgrading my GPU from the 6950 (1gb) to either RX 460 or R7 370. Yep this is a budget upgrade; with a budget of $180. I plan to try at least run Star Citizen at the lowest settings with playable frame rates, however if not that's fine as I also just want to upgrade from an old card to a newer one for stability and performance.
Also I have
-8gbs of RAM
-Core i3 2120 @3.3GHZ
Thanks guys for the input!
your cpu is also not good enough to run at minimum
minimum i5 + gtx 680/7970
you would want at least a rx 470 with an i5
