Upgrade help please?
zarikvicenty
So I have a HP Pavillion H8-1234, it's terrible I know but Im looking to upgrade this piece of junk. https://support.hp.com/si-en/document/c03359045
Those are my pc specs, anyway I'm not trying to spend too much so I was going keep the everything but the cpu, graphics card and psu. Does anyone have any idea what wattage psu I would need and also a recommendation for a graphics card would help a ton. I was also thinking about getting an amd fx 8350 because I think that's the best cpu for my socket type, thanks in advance
Most AM3+ motherboards are end of life now that AM4 is out. Not a lot of selection and prices are higher than in the past.
I would spend $30 on a bare Mid-Tower PC case. A good quality 500 watt power supply is commonly used.
GeForce GTX 1050 Ti
https://www.newegg.com/Product/Product.aspx?Item=N82E16814500410&Tpk=N82E16814500410
ASUS M5A97 R2.0
https://www.newegg.com/Product/Product.aspx?Item=N82E16813131873&cm_re=amd_970-_-13-131-873-_-Product
Mid Tower Computer Case
https://www.newegg.com/Product/Product.aspx?Item=N82E16811853003
Cooler Master SickleFlow 120mm fan
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103060
GeForce GTX 1050 Ti
ASUS M5A97 R2.0
