Upgrade my pc to reach 200+ fps (csgo) Help :D
CsgoAddicted
32
Okay guys So... Good morning my pc is cougar spike and my specs are::csgoa:
Cpu:Intel pentium G2358 4.0 dual core (OC)
Gpu:gt 730
Ram: 8gb
Windows 8.1 pro
In cso all all low settings with V sync off i reach 60-70 fps and i want to reach at least 200+
My budget is 250 euros and i was going to buy r9 380 msi but i saw that i bottleneck my cpu and requires 500 watt . So i went for Gtx 960 msi but i bottleneck again my cpu... I decided to stay with gt 730 and upgrade my Cpu to the best i5 out there (Intel core i5-4690K 3.50 ghz) for 250 euros, is it worth it? can i reach 200 fps?
btw my screen has 60 hz but i have v sync off tearing is not the problem Thanks for reading! :)
Do u know what Vertical Sync means? As i said i have g-sync and a free sync monitor (60 hz) so tearing is not problem...
maybe i'm not familiar wth what freesync is but if a monitor advertises 60hz then it is not sufficient for more than 60fps regardless of gsync/vsync. VG248QE is a great monitor for the price, 1080p 144hz 1ms, will make a night/day difference on CSGO.
As for GPU's, i have an evga gtx 980 ti sc & i get about 400-500fps on csgo. 200-400 on deathmatch though.
personally i'd choose nvidia over amd.
