Upgrade or keep and put in a dedicated graphics card?
ds3954
Motherboard - ASRock-Fm2A75
RAM - 16GB DDR3
Intergrated Graphics Card - AMD A8-6600K.
I want to play new games like COD WW2 etc and the current board stutters and hangs sometimes so what upgrade or better still a dedicated card without having to change mother boards. Budget is around £200
Your cpu is to weak to play new games without dropping below 30fps (fps will fluctuate a lot) adding a 1050ti in it will allow you to play the games but be prepared to not have a good experience with that cpu.
jaslion
I would be happy with 30fps i'm only getting around 20fps at best on some of the new stuff coming out.
Your cpu is currently below min spec for almost all new AAA games so it will be an unstable 30 fps if at all quite often.
Thanks guys, would they slot straight in without too much messing around with the current AMD board? According to the manual I have 2 x PCIe 2.0 x16 slots (PCIe2 @ x 16mode, PCIe4 @ 4 mode), 2 x PCIE 2.0 x 1 slot & 3 x PCI slots. Whatever that means (sorry not very technically minded with PC's) If it helps my actual card is Radeon HD 8570D and from a performance tester i had;
CPU mark - 5399, 49%
2D - 523, 46%
3D - 733, 41%
The whole passmark rating was 1460, 31%
Any advice is welcome as I can't afford to splash out on anything major like a new PC or motherboard at this time.
