My custom built PC will be seven years old in February. I'm trying to decide whether I should upgrade/replace some components to help it along, or go with a full rebuild. While a full rebuild may be the best value in the long run, I'm only a very casual gamer anymore so it's hard for me to justify the cost. My monitor is an 1440p60 IPS.
Here is what I am running:
If I update, I am thinking 8 GB of additional matching RAM, a new Power Supply since I'm told mine is too old and risky at this point, a Samsung 860 EVO 500GB (my current SSD works well, it's just too small), and something along the lines of an RX 580 8GB. I'd roll forward with the old i5-2400, motherboard, case and existing RAM.
If I went new, could you suggest a system that's a worthwhile upgrade that's not overly expensive for 1440p60 gaming? I don't need the newest AAA games at Ultra settings. I'm even cool with Fortnite at 1080 on my current system as it's required in order for me to have reasonable performance.
Thanks for any advice/help!
Intel Core i5 Processor i5-2400 3.10GHz 6MB LGA1155 CPU, Retail I5-2400BOX $188.99
1 x ($179.99) OCZ Vertex 3 VTX3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD) $179.99
1 x ($169.99) SAPPHIRE 100314-3L Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card $169.99
1 x ($89.99) OCZ ZS Series 650W 80PLUS Bronze High Performance Power Supply compatible with Intel Sandy Bridge Core i3 i5 i7 and AMD Phenom $89.99
1 x ($79.99) MSI H67A-G43 (B3) LGA 1155 Intel H67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard $79.99
1 x ($39.99) G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBXL
Coolermaster HAF Full Tower of some model
