Upgrade Suggestions For Mid-Range 4k build
Oct 17, 2018
Can anyone suggest a decent gaming-specific AMD based build that can handle 4k gaming within the £700-800 mark ($1000).
There are so many motherboards to chose from but have no idea what the differences between them all. This build would be for gaming and entertainment, no video editing or other CPU heavy stuff.
Thanks in advance
MERGED QUESTION
Question from dunkinspaces : "Is this a good build for gaming"
No, that is completely false. There's no scenario in which having a higher end PSU would make up for the lack of hardware. A solid 550W should be able to run just about anything, put that money saved back into the hardware. You also have an X470 motherboard with an LGA1151 CPU, those will not mix.
What is your overall budget?
