Upgrade system build
zanw2268
74
Hi I am looking to spend some money and upgrade a component or two in my current pc build, I will be using mostly multi application/video editing with it along with some gaming
-I would like a new cpu as I need more compute power, and want to overclock higher. So if someone could suggest a new and better Cpu Motherboard combo as well that would be great.
-What would be the next best water cooler for my cpu
-Does anyone know if/how I can overclock my ram currently untouched at 1866mhz
-What are some good gaming monitors at 1080 and 1440p
Cpu: fx 6300 @ 4.5ghz
Mobo:M5A97 R.20
Ram:Kingston hyperx Fury 16 gb (2x8) 1866mhz
Video card: HD7850 2gb 950 mhz
Psu: corsair 550 bronze
Ssd: kingston 120gb Ssd
Hdd: Western Digital 1TB
Cpu: Cooler: H40 All in One
Case: Phantom 410
Sound card: Xonar DG Asus
Windows 7 64 bit
On this bulid you can push around 4.7Ghz maybe little higher.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($285.98 @ Newegg Canada)
Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard ($163.98 @ Newegg Canada)
Total: $449.96
Generated by PCPartPicker 2015-06-16 07:11 EDT-0400
Witch cheaper mobo around 4.5Ghz
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard...
That's what I need then. I heard some people say the 6300 is better at video rendering then then 4690k and even 4790k.
What motherboard would you suggest to go with it? something that looks good
Total: $449.96
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard ($133.95 @ Vuugo)
Total: $419.93
Generated by PCPartPicker 2015-06-16 07:19 EDT-0400
http://www.bit-tech.net/hardware/2014/11/19/asrock-z97-pro-3-review/7
Latest posts
