So, I've got this PC and been running stock frequency on everything and decided that i want to O.C, now the problem is, my cpu hits around 65-70° on 100% load, Prime 95. Recorded with Core Temps, on 4.6gHz with stock voltage and did a stress test for 2-3 hours. I want to push it a bit more, seems like the cpu wants to go higher 😀 But the 212X is a bit noisy and quite warm as you can tell. Should i go for a Be Quiet Dark Pro 3(quite similar but less noisy and a tiny bit cooler) or for an AIO, CM masterliquids ML240 RGB(heard of leaks and i don't want this to happen 😛) Another option is to buy one more fan and use push-pull, plus one more at the front to push cold air from the top-front, as i only have one at the bottom-front and one as exit through the back.
Specs:
i5 7600k with 212X 4.6gHz
16 gb ram corsair vengeance 2400
Gigabyte GTX 1070
+25 on clock and +525 on memory
650 Evga PSU 80+ Gold
Z270X Ultra Gaming Gigabyte
Phanteks P400
Specs:
Gigabyte GTX 1070
Phanteks P400
