Upgrade Video Card/Power Supply?
TortoiseBoy
6
Hi Folks,
I have a Vostro 230 (mini tower) and it just has integrated video, but I would like better performance than that for games. I am looking to spend less than $100 on the video card. I don't need premium performance, but I would like to have games run at a reasonable frame rate. I have a 24" LCD panel running at 1920 x whatever. Anyway, I have been looking into video cards and I haven't found one with decent performance that will run on my 300w PSU.
1) Is there such a thing as a decent card that will run on my existing PSU?
2) If not, can you recommend a quality PSU upgrade (450w/500w?) that will fit in my Vostro mini tower that won't break the bank?
So, as usual, I want as much performance as I can get without spending a lot of money :)
Thanks so much for any help you can offer.
TB
What are your full system specs?(CPU/RAM/Mobo/etc.)
Do you happen to know the make/model of your power supply? How many amps are on the 12/v rail?
You could get a 5570,which would be an improvement, but at your resoultion it will put a lot of strain on it.I think it would be best to save up some more money to buy a power supply and a better grapihcs card.At your budget level and your current power supply you don't really have a lot of options.
Similar threads
