Upgrade wireless ac dual band card for Toshiba P75-A7200
Hello,
I have a toshiba p75-a7200 laptop that has the old Intel centrino wireless-n 2230 card. Is there an upgrade ac dual band card that works with this computer. I have had repair people tell me to only replace it with one that is proven to work.
well the repair people have to play it safe
I have replace numerous laptop old single band wireless devices with dual bands, without a single problem.
the only issue you will find the replacement card to find the same size format (ye there are 3 different models that I know (shape/size) wise.
Here is one I would buy to replace what you have:
Genuine Toshiba Satellite P75-A7100 Wireless Wifi Card PA5124U-1MPC
https://www.ebay.com/itm/Genuine-Toshiba-Satellite-P75-A7100-Wireless-Wifi-Card-PA5124U-1MPC/282966411922?epid=1128288030&hash=item41e21cca92:g:RkEAAOSwBSxa-pEF
and here is where the driver is for it
https://downloadcenter.intel.com/product/75439/Intel-Dual-Band-Wireless-AC-7260
Thank you for the help. I got the wifi card and installed the driver and it works great. Wow, what a difference. Everything loads super fast. Now I'm getting 115 - 118mbps download speeds. Fantastic. Thanks again
