Ok so what i had before was this build:
http://pcpartpicker.com/user/Zolton33/saved/rGDzK8
CPU
AMD Athlon II X2 270 3.4GHz Dual-Core Processor
Motherboard
MSI 760GM-P23 (FX) Micro ATX AM3+ Motherboard
2 G.Skill Value Series 4GB (1 x 4GB) DDR3-1333 Memory
Western Digital WD Blue 500GB 2.5" 5400RPM Internal Hard Drive
Asus Radeon R7 240 2GB Video Card
Antec 450W ATX Power Supply
LG GH24NSB0 DVD/CD Writer
Windows 10 64
Now i upgraded my cpu to an FX 8300
I have no plans to over clock and bought the cpu on sale as an upgrade so went with the stock fan that came with it. I installed it and had it on just web surfing for a long while to see how it does. I launch a game Ark Survival Evolved to be exact and i was waiting for my mods to install so i could play when my monitor goes black but the pc is still running and would not power off via its power button so i unplugged it checked my video card and all was well.
I also double checked my cpu fan was secured so i powered it up again all seems fine so i started monitoring the temperatures using cpuid hw monitoring. I noticed my temps are all over the place.
TMPIN0 min 24 max 38
TMPIN1 min 37max 47
TMPIN2 min 29 max 31
AMD FX 8300 Min 14 Max 46
AMD Radeon R& 240 min 32 max 36
Now all seems ok that is at idle while posting this. When i stressed it with Cpuid TMPIN1 hit up to 80 and my cpu was hitting closer to 60+
I was not sure on its accuracy so i tried out AIDA64 extreme. And not long into it less then 3 minutes screen went black and i had to unplug the pc again to shut it down as again the power button did nothing.
So this time i took my pc apart. Completely cleaned off the stock paste and put on some arctic silver to the cpu and put it back together. Not sure what is going on i tried AIDA64 Extreme again and when i saw it jumping to high this time stopped it. The weird thing? The temps kinda lingered there a while. Even when i went into task manager and killed the program. Eventually they did drop back down to normal and i reset the temps to monitor them as i post this to see the changes.
I hope it is not the stock cooler. But i guess it could be the cheap MOBO. I kind of suspected it may be the dual core optimizer that was installed playing havoc on the temps so i uninstalled it and will run another test after i post this after a pc restart to be sure it is gone from the equation. Any ideas on a specific cause? I'd hate to opt for a better cpu cooler when i've no plans to oc the cpu. But i will if that is the problem. Or i guess i could try the older heat sink i had on my other cpu if need be. So any ideas?
Edit to add just tried cpu z stress test while monitoring with cpuid hw monitor and temps were as follows:
TMPIN0 min 24 max 56
TMPIN min 37 max 70
TMPIN2 min 28 max 31
FX 8300 min 14 max 57
AMD Radeon R7 240 min 32 max 36
My case has 5 fans all set to exhaust 2 on rear one on side one on top and one in the front. I stopped the stress when it hit 70 myself on TMPIN1. Not sure what temp that is monitoring but i do not like it at all.
CPU
Motherboard
Windows 10 64
TMPIN1 min 37max 47
TMPIN min 37 max 70
