I just upgraded my Dell XPS8700 i7 from 4X4GB of Samsung memory. The motherboard had 2 white memory slots and 2 black slots. After going to Crucial, I found compatible memory and replaced 2 4GB sticks with 8GB sticks in the black slots and left 2 4GB sticks in the white slots. The computer still boots up and all looks okay, but it is taking a lot longer to boot up and to launch new programs. any ideas? I tried reading other posts and following some of the diagnostic advice. Below are the specs from different programs. Would appreciate any help that any of you can lend. Thank you so much.
Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Dell Inc. A08, 4/16/2014
SMBIOS Version 2.7
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Dell Inc.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Hardware Abstraction Layer Version = "10.0.17134.471"
Installed Physical Memory (RAM) 24.0 GB
Total Physical Memory 24.0 GB
Available Physical Memory 20.7 GB
Total Virtual Memory 27.5 GB
Available Virtual Memory 24.1 GB
Page File Space 3.50 GB
I ran CPU-Z for each of the 4 slots
overall frequency 3990.5MHz
DRAM Freq. 798.1 Mhz
FSBRAM 1:6
CAS# CL 11.0 clos
tRAS 28 clocks
tRFC 208 clocks
command rate 2T
Slots 1 and 3 are the new Crucial DDR3 8192 MBytes,
Max Bandwidth PC3-12800 (800MHz)
Dual Ranks
Part # CT102464BD 160B.c16
Slots 2 and 4 are the old Samsung DDR3 4096 Mbytes
Single Ranks
Part # 953E2E6C
thanks again,
Charlie
Frequency for all the slots shows JDEC#3 609Mhz JDEC#4 685 Mhz JDEC #5 761Mhz and JDEC #6
800Mhz
new voltage for al JEDEC shows as 1.35V, for old ones 1.5V
SMBIOS Version 2.7
BIOS Mode UEFI
FSBRAM 1:6
CAS# CL 11.0 clos
tRAS 28 clocks
tRFC 208 clocks
command rate 2T
Dual Ranks
Single Ranks
Part # 953E2E6C
thanks again,
Charlie
800Mhz
