So i upgraded the system, went from an MSI b150 motherboard to the Asus ROG maximus X. Stuck with the same CPU, added an m2 socket ssd (also plugged in my previous SSD with the OS), and added an upgraded graphics card. According to the manual everything is plugged as it should be.
When i fired it up, the lights would come on and fans would turn on but only for a SPLIT second, then everything shut back off. The fans were'nt even powered long enough to reach decent speed. So far i've unplugged everything except the monitor, mouse, and keyboard. I've also removed the graphics card. Same behavior. I guess next step is removing the m2 ssd, but i doubt that would change anything.
Any thoughts? I reused the standoffs already present in the ATX chassis, so i don't think its a grounding issue. Also had a Windows 10 boot usb ready to go.
