Old Specs:
AMD Athlon X4 880K
GTX 1050Ti OC Edition 4gb
8GB DDR3 RAM 1600MHz
Gigabyte GA-F2A78M-HD2 motherboard
EVO Labs Pentium p4 Model:E-600BR
Windows 10 Pro
New Specs
Intel i5 7600K
GTX 1050Ti
2x4GB DDR4 RAM 2400MHz
ASUS Z270-a Prime Motherboard
Windows 10 Pro
The power supply had a 4 pin power cable for the motherboard so I bought an 8 pin adapter. I believe everything is plugged in correctly can however I don’t get any signal on my monitor. Monitor is working perfectly fine I checked and I tried removing the GPU and using the integrated graphics. That didn’t work. GPU didn’t work. I removed one stick of RAM that still didn’t work. I have no idea what the issue is and I could really do with some help right now. Thank you
AMD Athlon X4 880K
Windows 10 Pro
New Specs
Intel i5 7600K
GTX 1050Ti
Windows 10 Pro
