upgraded PC and hit a problem
baradekai
Hi guys I recently tried to upgrade my PC with a New GPU, PSU, and an SAD. Now when I start my computer it shows the GO screen with press each to access start menu. After that it goes to a black screen with my computer specs and the Same press each for start menu message. If I press each it says start menu In the bottom right corner of the black screen without actually opening the start menu, and I can't access any other menus (such.as boot or bios) either. Can Anyone tell me how to fox this problem? Thanks.
When you first start, you need a monitor connected to the onboard graphics (if that is what you were using before) to set the primary GPU to the PCI or PCI express slot instead of the integrated graphics. Once changed, you can move your monitor to the GPU.
I just upgraded my main computer (new GPU), and Windows 8.1 didn't like it....I went through the repair options - end result - I had to reinstall the OS. Another 6-8 hours of fun....
I wasn't using the onboard graphics before, I just swapped to a bigger better card (gtx 545 to gtx 970) and if I plug the hdmi into the mono nothing loads and it just beeps at me.
