I do nWelcome to Toms forums.
what BIOS version is installed to the motherboard.
7B19v13.zip is the first version to support the i5-9400. earlier versions will not support the CPU at all and will exhibit what you describe.
https://www.msi.com/Motherboard/support/B360M-GAMING-PLUS#support-cpu
the b365 boards are 9th gen ready out of the box. the b360 boards will need software installed and that will require a supported CPU to install.
