i already had 16gb but i added 2 more sticks, they arent matching but are very similar and i heard thats enough for it to be compatible. it took a long time for me to be able to get it to boot, i think it was one of my usb devices or something after unplugging them all i was able to get to the bios, and now im able to get into my computer mostly fine and it registers all 4 sticks of ram but it gets stuck in a boot loop every time i try to set 3200mhz and gets auto set down to 2133 again
those are the two sets of ram in my system, theyre both rated the same referring to like
turning xmp on i remember always making my pc crash even before this but i was able to set the mhz just on my own by clicking the "3200mhz" option and thats normally always worked it's just now that also messes it up
G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin PC RAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C16D-16GVKB
Team T-FORCE VULCAN Z 16GB (2 x 8GB) 288-Pin PC RAM DDR4 3200 (PC4 25600) Desktop Memory Model TLZGD416G3200HC16CDC01
- DDR4 3200 (PC4 25600)
- Timing 16-18-18-38
- CAS Latency CL16
- Voltage 1.35V
