L lsoikc Distinguished Aug 17, 2014 55 1 18,535 Oct 18, 2020 #1 So right now, im gaming at 1080p 144hz. Im planning to switch to 1440 144hz gaming experience with around 800-1000$. What should i upgrade? Spec : i5-8400 Asrock B360 K4 2 x 8 DDR4 GTX 1070 8gb
Solution S S sizzling Oct 18, 2020 Are you happy with the FPS you get at1080p? If yes then probably just a monitor and new gpu assuming your psu is adequate.
S sizzling Titan Oct 18, 2006 27,224 3,268 112,240 Oct 18, 2020 Solution #2 Are you happy with the FPS you get at1080p? If yes then probably just a monitor and new gpu assuming your psu is adequate. Upvote 0 Downvote Solution
