[SOLVED] Upgrading from a GTX 950, needing help
therealityreaper
Commendable
Jan 11, 2019
26
Approximate Purchase Date: ASAP
Budget Range: ~250,
System Usage: Gaming
Are you buying a monitor: No
Parts to Upgrade: GPU, my powersupply :evga 450 bt 80+
Do you need to buy OS: Don't think so?
Preferred Website(s) for Parts: Honestly as long as it doesnt look like the dark web sure.
Overclocking: Y/ Maybe
Your Monitor Resolution: 1920x1080,
Why Are You Upgrading: I would like to be able to play R6/MW. Also im fairly sure my bottleneck is the GPU because I have a i7 3770K @3.40GHz
I didnt build this myself a friend of mine did and Im looking to get a little help thanks
Latest posts
