upgrading help opinions ?
FaZePULLOUT
Commendable
Jul 16, 2016
83
Hi, I have a pc I built, and I'm looking for something to upgrade in it.
What in your opinion should I upgrade?
PC BUILD
Case - Corsair Carbide Series SPEC 01
Fans - Corsair AF (3)x120mm
Motherboard - MSI b150 gaming m3
Cpu - i5 6600k@ 3.5
Cpu Cooler - Corsair H60 120mm Single Rad
Gpu - Intel HD530
Ram - Hyper X Fury (4x4gb) 16gb
Psu - EVGA 500w
Storage - Seagate 1TB
P.S If I run quad channel, but my cpu, motherboard only supports dual channel architecture . what will happen? thnks J.
Are you asking if you can run four RAM sticks? Sure you can run it fine, just because you have 4 RAM sticks does not mean it's "quad channel", you just four sticks in dual channel mode for each pair.
About an...
80 dollar budget, also could you help me on the last thing I don't know what would happen if i run quad channel, when my shit is dual channel aka cpu mobo
About an upgrade, looks like you have all new parts, what's there to upgrade? Unless you did not get a video card for it, which would be really silly not to get in a system like yours which was pretty clearly made for gaming.
For about $80 you can get a GTX 750 Ti, not worth to get anything less for your system, even that will hold it back a bit, spend a bit more and get a GTX 950, they are about $120-130 with rebates now.
I was thinking about getting a GTX 750 TI, but I couldn't find one cheaper than 95$. I'm more leaning to a 950, just because it's only 120 on amazon right now.
Thanks for your input though didn't really now what in gods green earth what quad channel was.
Sincerely, J
