Upgrading motherboard + cpu, but have a slight problem
Maester Trea
68
Hey so here's whats happening, i'm going to be switching out my AMD Cpu and Mobo for a Intel setup and i'm going to have to do a clean install of windows 8/8.1.
But the problem is i bought my computer prebuilt from newegg.com and the way they had windows 8 setup on there is i believe it was preinstalled and the key/activation code was on a little sticker on the side of my case. Considering i don't have a Windows CD or anything like that will I most likely have to drop another 100$ on buying a hardcopy of windows 8.1?
That copy of Win8 is bound to the motherboard according to the EULA for that license of Windows 8. So yes you will need to buy a copy of Windows if you plan on using another motherboard.
